scos Posted November 10, 2008 Posted November 10, 2008 I'm just now starting a new job in drafting after being out of school for a year and need a little help. I have using land desktop i've drawn a bridge at 1"=20' and need to make it 1"=50'. Thank you for any help. Quote
Tankman Posted November 10, 2008 Posted November 10, 2008 Modify scale, scale factor 0.4 Never used land, but frequently modify scale. I could be wrong, say what forum members? Quote
scos Posted November 10, 2008 Author Posted November 10, 2008 Thank you much.I'll give it a shot Quote
hotrodz0321 Posted November 10, 2008 Posted November 10, 2008 did you draw it at 1:1 and set your scale to 1"=20' or did you draw it at 1"=20'? Quote
scos Posted November 10, 2008 Author Posted November 10, 2008 1:1 With The Scale Set To 1" = 20' Quote
wannabe Posted November 10, 2008 Posted November 10, 2008 You just need to amend the scale of the viewport then, if your drawing is at 1:1. Quote
soleary Posted November 10, 2008 Posted November 10, 2008 1:1 With The Scale Set To 1" = 20' Good that you drew the model at 1:1. Your first post seems to suggests different From paper space, you can take a view of this model at whatever scale you like. There are a number of ways of applying the desired scales to the viewport. If you don't know how to do it, you can check it in help. I wouldn't advise changing the scale of the actual model by using the scale command. Leave it a 1:1. Quote
