Ravenstown Posted November 8, 2012 Share Posted November 8, 2012 I am having a problem with the electrical conduit disappearing when I change my model space from "2D wireframe" to "realistic" and go into 3D Orbit. All other entities remain but the conduit will disappear. This is a new problem that never has happened before with my current file. I work at two locations and it is happening on both computers (with the same file). Also in paper space... the viewports that are set to "realistic" are now having the same issue. Sometimes only portions of the conduit will show. I even try to toggle between 2D wireframe and realistic to get it to regen but no change. That used to work. Drawing file is just over 11MB. I use Autocad MEP 2013, Windows 7. Both computers have ample RAM and 3D video cards. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted November 9, 2012 Share Posted November 9, 2012 I think you have a RAM issue, try using CONCEPTUAL visual style instead of REALISTIC, that may help. As soon as you stop orbiting the image regenerates and displays properly, right? Quote Link to comment Share on other sites More sharing options...
Ravenstown Posted November 9, 2012 Author Share Posted November 9, 2012 When I exit the 3D orbit and the drawing regenerates the conduit does not re-appear. It only re-appears when I toggle back to 2D wireframe and set the view to TOP. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted November 9, 2012 Share Posted November 9, 2012 Is your DISPSILH value set to 1? If you orbit starting from 2D wireframe, can you see the conduit during the orbit? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 9, 2012 Share Posted November 9, 2012 Have you tried an Audit on the drawing? I'm just guessing MEP has that. You might try rebuilding the conduit. Quote Link to comment Share on other sites More sharing options...
Ravenstown Posted November 14, 2012 Author Share Posted November 14, 2012 Is your DISPSILH value set to 1? If you orbit starting from 2D wireframe, can you see the conduit during the orbit? Changed setting to 1 but the conduit disappeared as soon as i clicked on 3DORBIT command Quote Link to comment Share on other sites More sharing options...
Ravenstown Posted November 14, 2012 Author Share Posted November 14, 2012 Have you tried an Audit on the drawing? I'm just guessing MEP has that.You might try rebuilding the conduit. Tried AUDIT several times already... no errors every time Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 14, 2012 Share Posted November 14, 2012 Sounds more like a graphics card issue to me. Is hardware acceleration on or off? Quote Link to comment Share on other sites More sharing options...
Ravenstown Posted November 14, 2012 Author Share Posted November 14, 2012 Sounds more like a graphics card issue to me. Is hardware acceleration on or off? I just upgraded to a NVIDIA GeForce GTX 680 and doubled my RAM to 16GB. Where do I check the hardware acceleration setting? I pulled up one of my older CAD files (about 6 months old) and the conduit does not disppear when I go into 3DORBIT so it would seem like it would have to be in this peticular file. Maybe a display manager setting? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 14, 2012 Share Posted November 14, 2012 I would guess you need to rebuild the conduit then. It may be some MEP bug, I will move your thread to the MEP forum for you if you like? Quote Link to comment Share on other sites More sharing options...
Ravenstown Posted November 14, 2012 Author Share Posted November 14, 2012 How could it be a MEP bug if I have other drawing files where this does not happen? I opened an earlier version of this same file (about 1 month earlier) and everything is OK there, the display manager settings for CONDUIT appear to be the same. I don't know what it is but it only affects the conduit regardless of the layer it is on. Other entities of the same layers still appear. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 14, 2012 Share Posted November 14, 2012 That's why they call them BUGS, they bug you. Quote Link to comment Share on other sites More sharing options...
Alzer Posted November 15, 2012 Share Posted November 15, 2012 If you want to check your video card settings use the 3DCONFIG command. It seems odd that one particular object is disappearing. 3dconfig might help. Quote Link to comment Share on other sites More sharing options...
