R3nzoku Posted November 12, 2012 Posted November 12, 2012 Hello, I found this magical program: http://www.lee-mac.com/autolabelattributes.html; but I have no ideea how to build the kind of block with atributes. Can some1 upload a dwg or smth so I can take it from there? Quote
Lee Mac Posted November 12, 2012 Posted November 12, 2012 Hi, The program will work with any attributed block, however, you will need to alter the name of the block and attribute tag listed at the top of the source code where noted (Line 18 & 19) to suit your block: (setq *blockname* [highlight]"block"[/highlight] ;; Name of Block to be Updated *blocktag* [highlight]"tag"[/highlight] ;; Attribute Tag to be Updated ) Ask if you need further assistance. Lee Quote
ADSK2007 Posted April 20, 2013 Posted April 20, 2013 Hello Lee I have one question, Is it possible to have two attributes in a block and have the lisp routine work on both? If yes, then how can I add another attribute name to your program? Best Regards Adsk Quote
Lee Mac Posted April 21, 2013 Posted April 21, 2013 I have one question, Is it possible to have two attributes in a block and have the lisp routine work on both? If yes, then how can I add another attribute name to your program? The current version of the program will only permit you to renumber a single attribute. Quote
kolonet Posted November 29, 2014 Posted November 29, 2014 How can we give a specific letter to attributes? For example B1 B2 B3... Quote
