Rooster Posted November 12, 2012 Share Posted November 12, 2012 I've searched all over the interweb for this, but no joy: what I want is to create a block which contains a bit of text displaying the scale (X scale only) of the block. Then, if I change the block's scale it will also update. Is this possible?? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 12, 2012 Share Posted November 12, 2012 Use Dtext or Mtext with a FIELD. Quote Link to comment Share on other sites More sharing options...
Rooster Posted November 12, 2012 Author Share Posted November 12, 2012 I've tried this every way I can, but can't get it to work. I've added a field to my block to display the X Scale, added my prefix & suffix etc etc which is all fine, but it doesn't update when I change my block's scale. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted November 12, 2012 Share Posted November 12, 2012 Certainly sounds like the answer will be yes, but have you checked your FIELDEVAL variable setting? Quote Link to comment Share on other sites More sharing options...
Rooster Posted November 12, 2012 Author Share Posted November 12, 2012 Thanks for the suggestion - it' set to 31. Quote Link to comment Share on other sites More sharing options...
dbroada Posted November 12, 2012 Share Posted November 12, 2012 I don't think this can (easilly) be achieved. This is along the same lines as the "can I type 1 piece of text to display in many places. Some claim you can but the hoops they jump through are in my mind too complicated to be of pratical use and nearly always involves selecting the current block as the source of the text or, in this case scale. You can get a block to reference itself to display the scale but once you write the block the scale reference links back to the original block. I would be happy for somebody to prove me wrong though. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 12, 2012 Share Posted November 12, 2012 If the text is in the block, try using Attributes with fields and using ATTSYNC to update. Quote Link to comment Share on other sites More sharing options...
KiLLiNG-TiME Posted November 12, 2012 Share Posted November 12, 2012 It has to be an attribute "Block Place Holder" field is the trick.. remember to regen Heres a nice step by step link for you http://www.cad-addict.com/2009/01/au...ic-blocks.html Quote Link to comment Share on other sites More sharing options...
dbroada Posted November 13, 2012 Share Posted November 13, 2012 It has to be an attribute "Block Place Holder" field is the trick.. Thank you KT. I have never used the "block place holder" field before. Must find a use for it. Quote Link to comment Share on other sites More sharing options...
KiLLiNG-TiME Posted November 13, 2012 Share Posted November 13, 2012 Thank you KT. I have never used the "block place holder" field before. Must find a use for it. Your welcome, you will find many uses for it as its the only way to apply certain fields "block fields" when in the block editor, have fun Quote Link to comment Share on other sites More sharing options...
Rooster Posted November 21, 2012 Author Share Posted November 21, 2012 Thanks KT - I will give this a go. Shame you have to regen with each change though.... Quote Link to comment Share on other sites More sharing options...
KiLLiNG-TiME Posted November 21, 2012 Share Posted November 21, 2012 Thanks KT - I will give this a go. Shame you have to regen with each change though.... Your welcome hope it works for you. Regen Thats AutoCad for you lets see regen for the sheet set manager if you update a sheet, regen for linestyles if linked to annotation scaling, i could go on .. Quote Link to comment Share on other sites More sharing options...
Rooster Posted November 21, 2012 Author Share Posted November 21, 2012 Well, that almost works how I want it to. I have re-defined my block with the scale attribute showing, and after re-scaling (and of course a regen!) it shows the new scale just right. I've then tried to use it on a live drawing where I need to use BLOCKREPLACE to replace my colleague's block with this new one. Problem is that doing a BLOCKREPLACE does not show the attribute - this only displays if I insert a new block. Any ideas to get round this? Quote Link to comment Share on other sites More sharing options...
KiLLiNG-TiME Posted November 21, 2012 Share Posted November 21, 2012 (edited) My bad i forgot is was "block" scale field so yes you will be fine with attsync damn my day job Edited November 21, 2012 by KiLLiNG-TiME Quote Link to comment Share on other sites More sharing options...
Rooster Posted November 21, 2012 Author Share Posted November 21, 2012 aww.... but having said that, I have just done attsync on my replaced block and my scale now shows up! Quote Link to comment Share on other sites More sharing options...
KiLLiNG-TiME Posted November 21, 2012 Share Posted November 21, 2012 aww.... but having said that, I have just done attsync on my replaced block and my scale now shows up! Yes your lucky because the field is only related to the block Glad you got there in the end Quote Link to comment Share on other sites More sharing options...
