Has anyone got this error and knows how to fix it?
Fatal Error: Unhandled Access Violation Writing 0x01c4 Exception at 84914dh.
What were you attempting to do when the error occurred?
I was drawing a line on a blank new page when the message came up.
I just downloaded the latest service pack and tried it again and now im getting the same message but with different numbers:
Fatal Error: Unhandled Access Violation Writing 0x7c76434e Exception at 1167013h.
Have you tried a REPAIR of the installation?
Through the Windows Control Panel via Add/Remove programs.
Do you exchange drawings with other people/companies?
Okay i'll have to try that. We PDF our drawings before we send them to other people/companies.
Do the other companies send you actual DWG files that you then work on? Yes or no?
I just tryed doing the repair that you mentioned and i still get the message.
When did this problem first happen?
Anyone else having the same problem?
What OS are you using?
Do you have any anti-virus program currently running in the background?
This first started about 2 weeks ago.
I'm the only one having this problem. The program is on another computer but its working fine for them.
Im using Windows XP.
I have an antivirus program but its not running in the background.
Have you kept XP current with critical updates from Microsoft?
Add AutoCad LT to the Do Not Scan or the ignore list(s) in your virus software. That way, it won't try to examine everything AutoCad does. We're not saying it will cure the issue, it is just that virus software often make memory access viloations more frequent while using resource hogs like AutoCad.
If your Anti-virus software is installed and not physically turned off, closed, canceled or something, then it is running "in the background". In computer jargon, "running in the background" means it is running, you can't see it running, and it requires no intervention.
What other programs do you run?
Did you or IT use a registry cleaner?
