I keep getting this error code whenever I try to print to a PDF document from my PDF print driver. It keeps crashing the program and having me shut it down.
Unhandeled Access Violation reading 0x6c302be0 Exception at 6c302be0h
Would like to know if there is away to fix this?
do you have a pdf reader? (Adobe reader)
Is your PDF driver the standard one Autocad provide or another one.
You could try searching for 'CutePDF' and installing that one as an alternative
Did it just start happening?
Does this occur in one file, a few files or all files?
It occurs for any files, not one in particular. I have been using CAD since i was in HS. I have come across some goofy stuff, but this is really weird. I have worked my way through settings and my last resort is download a different pdf print driver and see if that works. Not what I really want to do but may be the only solution.
I guess the other part that I did not mention which would have been good to know is that I am using CAD on my Mac going through Parallels.
