Why will this (getvar 'dimscale) not work on windows 7?
clint0577
This works just fine on the other computers but the 2 computers running windows 7 won't work. It's supposed to reat 1" = 20' when ran but it reads 1" = ' on the computers running 7
(defun c:dsc ()
(setq DS (rtos (getvar 'dimscale)))
(setq dwg-SCALE (substr DS 1 (- (strlen DS) 5)))
(SETQ DTE (STRCAT "1\" = " DWG-SCALE "'"))
 (if
   (and (not
          (eq (setq OldTxt "Scale") "")
        (not
          (eq (setq NewTxt dte) "")
    (if (setq ss (ssget "x"
                        (list '(0 . "TEXT,MTEXT")
                              (cons 1 OldTxt)
                              (cons 410 (getvar 'ctab))
      (repeat (setq in (sslength ss))
        (setq en (entget (ssname ss (setq in (1- in)))))
        (entmod (subst (cons 1 Newtxt) (assoc 1 en) en))
Ok so for some reason, when the dimscale is set at 20, everything works fine but when it's set to any other, 30, 40, 50, 60, 100, 200, I had to change the code from 5 - 3
changed to
(setq dwg-SCALE (substr DS 1 (- (strlen DS) 3)))
what a beating. so now I have to have 2 commands to do the same thing. If you're using dimscale 20 then this if you're using dimscale 30, 40, 50, 60, 100 or 200, then another
here's my entire code
;INFO
(DEFUN C:INFO ()
(command ".osnap" "NOD,end,INT,CEN,mid")
(SETQ CL (GETVAR "CLAYER"))
(COMMAND "LAYER" "S" "LEGAL" "")
(setq me (getstring t "\nDrawn By: "))
 (if
   (and (not
          (eq (setq OldTxt "Drawn By") "")
        (not
          (eq (setq NewTxt me) "")
                              (cons 1 OldTxt)
 (if
   (and (not
        (not
                              (cons 1 OldTxt)
    (setq d (rtos (getvar "CDATE") 2 6)
         yr (substr d 3 2)
         mo (substr d 5 2)
        day (substr d 7 2)
(SETQ DTE (STRCAT MO "/" DAY "/" YR))
 (if
   (and (not
          (eq (setq OldTxt "Date") "")
        (not
                              (cons 1 OldTxt)
(setq GFN (getstring t "\nType the GF Number: "))
 (if
   (and (not
          (eq (setq OldTxt "GF#") "")
        (not
          (eq (setq NewTxt gfn) "")
                              (cons 1 OldTxt)
(setq dwg-name (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 4)))
 (if
   (and (not
          (eq (setq OldTxt "Job#") "")
        (not
          (eq (setq NewTxt dwg-name) "")
                              (cons 1 OldTxt)
Ok so I'm working through this all by myself haha. I just added the code to look for the 1" = ' and replace also. Good talk guys. Good talk!
 (if
   (and (not
        (not
                              (cons 1 OldTxt)
(setq DS7 (rtos (getvar 'dimscale)))
(setq dwg-SCALE (substr DS7 1 (- (strlen DS) 3)))
 (if
   (and (not
          (eq (setq OldTxt "1\" = '") "")
        (not
                              (cons 1 OldTxt)
Edited by clint0577
