little "green dot" at center of x y axis is missing
I cannot get the "green dot" that usually appears at the intersection of the axis to show up.
Not sure what I clicked on to delete it.
if I go into sketch in applications options can't find anything to turn it off or on.
the axis is there, but no "green dot".
any ideas what I did or how to make it reappear.
thanks.
I remember the auto project origin becoming a standard process is inventor, in the old days we had to project it ourselves. Not often it switches it's self off, you may have deselected it in options menus. Click OPTIONS>APPLICATION OPTIONS>SKETCH and select AUTOPROJECT PART ORIGIN.
  • 2 weeks later...
Thank you Laser....that was it.
The document I suggested you read says the same thing!
