clint0577
one point relative to another for starting text
clint0577
In this lisp I'm trying to replace 4 blocks that pretty much do the same thing. I want the user to Click the point they want to use for the center of the text and the have the code calculate a certain distance, say 3.5 below on the Y axis for the next line of text.
;INSERT STREET NAME & R.O.W.
(DEFUN C:STRN ()
(SETQ CL (GETVAR "CLAYER"))
(command ".osnap" "NONE")
(setq DS (getvar 'dimscale))
(SETQ SNTW (* DS 3))
(SETQ RWTW (* DS 1.5))
(SETQ SHS (* DS 0.13))
 (setq pt1 (getpoint "\nPick insertion point for Street Name : "))
(setq sn (getstring t "\nType the Street Name: "))
(setq sr (getstring t "\nType the Right Of Way Enter VW for Variable Width or P for Public: "))
(SETQ SRW (STRCAT SR "' R.O.W."))
(COMMAND "LAYER" "S" "STREET_NAME" "")
(COMMAND "MTEXT" "_non" pt1 "J" "BC" "S" "STANDARD" "H" SHS "W" SNTW sn "")
(SETQ RHS (* DS 0.08))
(SETVAR "CECOLOR" "140")
(COMMAND "MTEXT" PAUSE "J" "BC" "S" "STANDARD" "H" RHS "W" RWTW sRW "")
(SETVAR "CECOLOR" "BYLAYER")
(COMMAND "CLAYER" CL)
(command ".osnap" "NOD,end,INT,CEN,mid")
(setq OldTxt "VW' R.O.W.")
(SETQ vwrw (STRCAT "VARIABLE WIDTH R.O.W."))
(setq ss (ssget "x" '((0 . "TEXT,MTEXT"))))
(setq i (sslength ss))
(while (not (minusp (setq i (1- i))))
	(setq oText (vlax-ename->vla-object (ssname ss i)))
	(setq Txt (vlax-get-property oText 'TextString))
	(if (vl-string-search OldTxt txt)
			(setq newChg (vl-string-subst VWRW OldTxt txt))
			(vlax-put-property oText 'TextString newchg)
			(vlax-invoke-method oText 'Update)
(setq P "P' R.O.W.")
(SETQ PRW (STRCAT "PUBLIC R.O.W."))
	(if (vl-string-search P txt)
			(setq newChg (vl-string-subst PRW P txt))
Share this post
Link to post
BIGAL
One of the things you can get from VL is "Vla-get-Insertionpoint txt" then just use a polar to work out next text point.
Share this post
Link to post
clint0577
Wow man! Thanks! That worked great!
(DEFUN C:STR ()
(SETQ RWO (* DS 0.175))
 (setq pt1 (getpoint "\nPick Insertion Point: "))
(SETQ PT2 (polar PT1 (DTR 270.0) RWO))
(setq sr (getstring t "\nType the Right Of Way Enter V for Variable Width or P for Public: "))
(COMMAND "MTEXT" "_NON" PT2 "J" "BC" "S" "STANDARD" "H" RHS "W" RWTW sRW "")
(setq OldTxt "V' R.O.W.")
Share this post
Link to post
BIGAL
Just a suggestion it really doesn't matter your method works for osnaps
(setvar "osmode" 0) ; no snaps
(setvar "osmode" 47)   ; (command ".osnap" "NOD,end,INT,CEN,mid")
;just set osnaps then OSMODE will give number
;also
(setq oldsnap (getvar "osmode"))
(setvar "osmode" oldsnap)
Share this post
Link to post
