Is possible ?
In vlr-mouse-reactor , i find ( :vlr-begindoubleclick , :vlr-beginrightclick)
Exists Mouse Move ?
Thanks
To my knowledge, there is no reactor that is triggered by movement of the mouse.
The alternative would be to use the grread function to detect user input in the form of mouse movement, however, unlike a reactor, this function will take focus over all other actions.
Visual LISP currently does not support a mouse reactor 'move' event, however, the GRREAD LispFunction does (sort of).
The only other way that I am aware of, is to employ a PointMonitor event handler using the .NET API, as I demonstrate in this post.
HTH
** Edit to add - Lee, you speedy bloke! LoL
8)
Though, its encouraging that we're echoing each other's comments :thumbsup:
I resolved my problem using using (: vlr-commandwillstart), before any command.
Instead of using the mouse event, I'm using the event before executing a command
thanks to all ;)
(if (null *save-reactor2*)
   (setq *save-reactor2* (vlr-command-reactor nil '((:vlr-commandwillstart  . teste))))
(defun teste ( reactor params )
(if (= (getvar "ctab") "Model")
 (layer-on)
For me to have the fortunate coincidence of echoing a mentor, is something to be proud of, in deed. :beer:
Edited by BlackBox
Phrasing
