Is it possible to assign colour to faces in 3ds max?
As the title says,
I have a model which has came over from invenntor in a single piece(attached if you will) and I need to colour certain parts a different colour from the rest.
Is this possible to do?
Or
Is it possible to un-attach an object? Split it up into user-defined regions?
cheers
I deattached the faces using the face select in editable mesh. Then selected the de-attached parts and coloured them separately.
I really like the method that you advised though, I shall try that later today!
