Casio47 Posted November 18, 2012 Posted November 18, 2012 Hello All... I have a feeling this question has been asked again & again...and yes ReMark, I did a search on it. If I wish to create an arrow, which will joggle all over my drawing, to represent a work flow, how can I do this? In other words, how do I place an arrowhead at the end of my polyline, and areas along the polyline, as it reaches it's finial destination? Thanks for the help! Quote
fuccaro Posted November 18, 2012 Posted November 18, 2012 How about changing the width for the last segment of the polyline? That segment can have a desired start width and zero end width, so it will look like a triangle (or an arrow head, if you wish). Quote
ReMark Posted November 18, 2012 Posted November 18, 2012 Create a block then use either the Divide or Measure command, Block option, to place the arrow head at set intervals. Another option might be a custom linetype that emulates arrows such as - - - -> - - - - > - - - - >. Get the idea? "Joggle all over...?" You must be thinking of Santa Claus. Or jello. Quote
Casio47 Posted November 18, 2012 Author Posted November 18, 2012 A custom linetype, that's actually a pretty good idea...I'll need to work on that one. Quote
SLW210 Posted November 18, 2012 Posted November 18, 2012 Make a linetype would be easiest for using again and again. See THIS THREAD. Quote
Casio47 Posted November 18, 2012 Author Posted November 18, 2012 Make a linetype would be easiest for using again and again. See THIS THREAD. Sorry, posted to the wrong thread... I'm doing something wrong here...I have unzipped the ltfly.vlx to my desktop. I'm not following you on the dragging part of it you write of in your instructions? I'm also getting an unrecognized command on the APPLOAD command. Not sure what to do? Thanks for the help Quote
MSasu Posted November 18, 2012 Posted November 18, 2012 I believe that you stated in other thread that you are using an AutoCAD clone; the VLX format is compiled AutoLISP and most probably isn't supported by that application. Can you post a picture of the linetype you are looking for? Quote
MSasu Posted November 18, 2012 Posted November 18, 2012 Please check the linetype definition from this previous thread; it seems to be what you were looking for. Quote
Casio47 Posted November 18, 2012 Author Posted November 18, 2012 I believe that you stated in other thread that you are using an AutoCAD clone; the VLX format is compiled AutoLISP and most probably isn't supported by that application.Can you post a picture of the linetype you are looking for? You are correct, I am trying this with DraftSight today, however, when I get to work tomorrow Ill try it on AutoCAD 2010. Having said this, I'm a rookie here with AutoCAD. I did look at the "previous thread" you speak of, and these arrow lines will work fine. The tread reads of creating a file with a .lin extension. If I crate this new file, with the new code, will it load when I select the linestyle in the layers manager...or do I browse for the file, and then will it load? And, is this the same idea with the post of SLW210 writes of? Thanks Quote
MSasu Posted November 18, 2012 Posted November 18, 2012 In AutoCAD when need to load a linetype definition in current drawing you need to call the LINETYPE command and then chouse Load - you will need to point to a native or custom collection of line types. Those are simple text (ASCII) files with LIN extension. You may add the said definition to one of native collections shipped with AutoCAD (acad.lin or acadiso.lin) or create a custom file. I suggest you to use the second solution since will be easier when need to migrate. Again, this is the situation in AutoCAD; in your tool you will need to discover the equivalent approach. Quote
Casio47 Posted November 18, 2012 Author Posted November 18, 2012 Ya-HOO!! It's working! I found where the .LIN files are stored in DraftSIGHT. I made a new text document and copy / paste: *EXIT_LINE,Exit Path line -- > -- > -- > -- > -- > -- > -- > -- > A,1,-.3,[">",STANDARD,S=1.5,R=0.0,X=-.1,Y=-.75],-1.5 It's not exactly correct, the lines between the >'s are not centered, but it's a start. Thanks Quote
nod684 Posted November 19, 2012 Posted November 19, 2012 Hello All...I have a feeling this question has been asked again & again...and yes ReMark, I did a search on it. If I wish to create an arrow, which will joggle all over my drawing, to represent a work flow, how can I do this? In other words, how do I place an arrowhead at the end of my polyline, and areas along the polyline, as it reaches it's finial destination? Thanks for the help! if you are to use it in minimal, you can just make a 2 connecting polyline and adjust the end width of the last polyline.. but if will be using it more often in workflows, what i did is i make a line type out of shape so i can just easily draw the path, change the linetype then that's it! Quote
MSasu Posted November 19, 2012 Posted November 19, 2012 the lines between the >'s are not centered That is from the font you have associated with Standard style - just adjust the part I highligthed with red in linetype definition to get them in the right location: *EXIT_LINE,Exit Path line -- > -- > -- > -- > -- > -- > -- > -- > A,1,-.3,[">",STANDARD,S=1.5,R=0.0,X=-.1,Y=[color=red]-.75[/color]],-1.5 Quote
viviancarvalho Posted November 19, 2012 Posted November 19, 2012 I do require arrows many a time in my drawings. I made it simple by using a small lisp. This could be very primitive & many of the lisp Gurus can help make it more better. Just appload the attached file in autocad & type sar at the command prompt. Hope this would be helpful DRAWING ARROWS.lsp Quote
nod684 Posted November 20, 2012 Posted November 20, 2012 I do require arrows many a time in my drawings. I made it simple by using a small lisp. This could be very primitive & many of the lisp Gurus can help make it more better.Just appload the attached file in autocad & type sar at the command prompt. Hope this would be helpful very nice routine thanks for sharing vivian Quote
MSasu Posted November 20, 2012 Posted November 20, 2012 @viviancarvalho: I will do some comments on your routine architecture, if you don't mind: You ask for insertion point, but the arrow is drawn at the other end, which is also used as reference for rotation; whouldn't be the other way? Since the layer name may be subject of user modification, then he/she must be aware that it is used in more than one place and modify it accordingly; by using a dedicated variable will ensure that he/she don't miss one spot. A good programming practice is to use an underline ("_") in front of commands and options to ensure it will works also on localized AutoCAD. Since you are affecting the default polyline width, this should be restored too, as you did with other system variables. ... [color=magenta](setq layerToUse "GRILLE")[/color] ; The layer name can be changed (if (null(tblsearch "[color=magenta]_[/color]layer" [color=magenta]layerToUse[/color])) (command "[color=magenta]_[/color]layer" "[color=magenta]_[/color]n" [color=magenta]layerToUse[/color] "[color=magenta]_[/color]c" "30" [color=magenta]layerToUse[/color] "") (princ)) [color=magenta](setq oldPlWid (getvar "PLINEWID"))[/color] (command "[color=magenta]_[/color]pline" a2 "[color=magenta]_[/color]w" "0" "0" a4 "[color=magenta]_[/color]w" "75" "0" a5"") [color=magenta](setvar "PLINEWID" oldPlWid)[/color] (setq sa(entlast)) (command "[color=magenta]_[/color]change" sa "" "[color=magenta]_[/color]p" "[color=magenta]_[/color]la" [color=magenta]layerToUse[/color] "") ... Quote
viviancarvalho Posted December 2, 2012 Posted December 2, 2012 Thanks Mircea for your comments. Will be remembered next time. Regards, Vivian Quote
viviancarvalho Posted December 2, 2012 Posted December 2, 2012 very nice routine thanks for sharing vivian I would be more than happy if it would help you Regards, Vivian. Quote
nod684 Posted December 2, 2012 Posted December 2, 2012 I would be more than happy if it would help you Regards, Vivian. Yes it is vivian Quote
