Hi guys,
I am new to autocad.
When I draw somenthing and try to dimension it.I can not see my text (the dimension) they are too small,,,how can I adjust the dimension style etc...
thanks,
tomyzoom
Hi guys,
thanks,
tomyzoom
type STYLE at the command line...
click NEW and give it a name
Select your desired font
under height just put 0
then type DIMSTYLE (make sure you know the dimstyle name that you wish to change)
Click Modify
Under TEXT tab, select text style (the new style that you just made)
then input the TEXT HEIGHT (commonly 1.8 to 2.5)
adjust "OFFSET from DIMLINE" based on height of text (can be 1/2 or 1/4 the height of the text)
Under FIT TAB, type input your desired "OVERALL SCALE"
Or if you are very new just look at the property box and change it over there
you do have to select the dimension you want to change or even all of them
Click Modify
thanks for your help!
