mythology2 Posted November 24, 2012 Posted November 24, 2012 Hey, all. I'm using 3ds max 2013 and I have a floor plan which I have placed on a plane for reference. I'm using splines to 'map' out certain areas. (walls etc) The only problem is that when dragging out spines the lines are white in color, so is most of my floor plan. Therefore I can't see what I'm dragging out very well. Where in max preferences can I change the color of the splines from white to another color when dragging them out? Thanks Quote
Cad64 Posted November 24, 2012 Posted November 24, 2012 I don't use Studio Max anymore, but this should help: http://www.3dmax-tutorials.com/Object_Color_Dialog.html Quote
mythology2 Posted November 25, 2012 Author Posted November 25, 2012 Customize User interface/ Colors tab/ Elements dropdown--- Geometry Selection box choices; SELECTION (this is the active selection) Adjust the color on the right using the swatch. Quote
