sheherezade Posted November 25, 2012 Posted November 25, 2012 Do you need to use the join command on an object before making it into a dynamic block? I have these stairs I need to scale down to fit my floorplan, but when I place grips on it in order to scale them down, I can only scale of the block while the rest becomes totally distorted. Quote
Dadgad Posted November 26, 2012 Posted November 26, 2012 (edited) Don't use grips, just scale them. Or you could wblock them, and then scale them along an axis. Edited November 27, 2012 by Dadgad Quote
sheherezade Posted November 26, 2012 Author Posted November 26, 2012 My stairs are supposed to be 1849x1950mm. I use the reference point option on the scale command, but if I manage to scale the length down to 1849, the height also changes proportionally, and vise versa if I scale the height. How do I work around this so I get the size I want? Quote
supercell Posted November 26, 2012 Posted November 26, 2012 Do you want to keep the 1849mm and change the 1950mm? If so make the stairs into a block and with the block selected open the properties dialog box (ctrl + 1 will toggle it on and off). There will be a x, y, z, scale variable. Adjust the appropriate one to create a NUS Non Uniform Scale block. You will need to do a little math to work out what percentage to scale it by. Ie To reduce it by 50% in the Y axis would be X=1 Y=.5 Z=1 Otherwise you could create a dynamic block with a linear parameter and a stretch action. There are some good dynamic block tutorials on youtube Hope this helps Quote
