sinnerboy Posted November 26, 2012 Posted November 26, 2012 (edited) I need a lisp to find all xrefs and moves them onto a layer called Xrefs. I attempted to do this myself ( lisps are not "my thing" at all) by editing this very useful lisp which (successfully) finds all viewports and puts them on a layer called ZPB_VPORT (defun C:vpget (/ a1 b1 index b1 ln) (command "-layer" "m" "ZPB_VPORT" "P" "N" "ZPB_VPORT" "") (setq a1 (ssget "X" '((0 . "VIEWPORT"))))) I've made several attempts without success Obviously I don't have a clue what I'm doing ..... Edited November 27, 2012 by SLW210 Added CODE TAGS! Quote
Least Posted November 26, 2012 Posted November 26, 2012 see here --> http://www.cadtutor.net/forum/showthread.php?47349-XRefsToLayers.LSP-Move-XRefs-to-corresponding-layers Quote
Tharwat Posted November 26, 2012 Posted November 26, 2012 Try this .... (defun c:Test (/ xr i vl) (vl-load-com) (if (tblsearch "LAYER" "Xrefs") (if (setq xr (ssget "_x" '((0 . "INSERT")))) (repeat (setq i (sslength xr)) (if (vlax-property-available-p (setq vl (vlax-ename->vla-object (ssname xr (setq i (1- i))))) 'Path) (vla-put-layer vl "Xrefs") ) ) ) (alert "Layer < Xrefs > is not found in drawing ") ) (princ) ) Quote
Lee Mac Posted November 26, 2012 Posted November 26, 2012 Another: ([color=BLUE]defun[/color] c:xr2lay ( [color=BLUE]/[/color] bd en in la ss xr ) ([color=BLUE]setq[/color] la [color=MAROON]"XRefs"[/color]) [color=GREEN];; Layer for XRefs[/color] ([color=BLUE]while[/color] ([color=BLUE]setq[/color] bd ([color=BLUE]tblnext[/color] [color=MAROON]"BLOCK"[/color] ([color=BLUE]null[/color] bd))) ([color=BLUE]if[/color] ([color=BLUE]=[/color] 4 ([color=BLUE]logand[/color] 4 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 70 bd)))) ([color=BLUE]setq[/color] xr ([color=BLUE]vl-list*[/color] [color=MAROON]","[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 2 bd)) xr)) ) ) ([color=BLUE]if[/color] ([color=BLUE]and[/color] xr ([color=BLUE]setq[/color] ss ([color=BLUE]ssget[/color] [color=MAROON]"_X"[/color] ([color=BLUE]list[/color] '(0 . [color=MAROON]"INSERT"[/color]) ([color=BLUE]cons[/color] 2 ([color=BLUE]apply[/color] '[color=BLUE]strcat[/color] ([color=BLUE]cdr[/color] xr))))))) ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] in ([color=BLUE]sslength[/color] ss)) ([color=BLUE]setq[/color] en ([color=BLUE]entget[/color] ([color=BLUE]ssname[/color] ss ([color=BLUE]setq[/color] in ([color=BLUE]1-[/color] in))))) ([color=BLUE]entmod[/color] ([color=BLUE]subst[/color] ([color=BLUE]cons[/color] 8 la) ([color=BLUE]assoc[/color] 8 en) en)) ) ) ([color=BLUE]princ[/color]) ) Quote
sinnerboy Posted November 26, 2012 Author Posted November 26, 2012 Wow - thank you all . Fantastic. Quote
SLW210 Posted November 27, 2012 Posted November 27, 2012 sinnerboy, Use CODE TAGS for code NOT Quote Tags in the future. Quote
sinnerboy Posted November 28, 2012 Author Posted November 28, 2012 Okay no problem I will. And thanks again for all the help on here. Quote
