AutoCAD Electrical Titleblock
Guys,
I'm using AutoCad Elec 2013 and I'm looking to find out how to change my title block 'project value' from 'line1, line2 etc' to some thingmore descriptive.
Any ideas?
I believe that information is controlled through a text file that can take one of two forms. It can be the default_wdtitle.wdl or the _wdtitle.wdl file.
  • 1 month later...
ReMark is correct, but I'll supply a bit more detail in case you need it. do a search on your machine for the default_wdtitle.wdl file and open it with notepad. Insert the following:
LINE1=Customer:
LINE2=Description 1:
LINE3=Description 2:
LINE4=Watermark:
LINE5=Job Number:
LINE6=Date:
LINE7=Drawn By:
LINE8=Checked By:
LINE9=Approved By:
LINE10=Scale:
LINE11=Revision:
See if this helps. The Tags in the title block then need to be mapped to these lines also in order for the whole system to work. I know this works for our title block, but they may be different for others.
I can give you more help with this if you need it.
