Create Subassembly from Polyline
Hello,
I have made several subassemblies from polylines with success. No problems with codes or behavior in an assembly. I do have problems adding them to a toolpalette. If I drag the subassembly to the toolpalette I get a small, black circle with a diagonal ‘no-can-do’ line through it. If I make the subassembly a block there is no problem adding the block to the toolpalette. Since these are shared toolpalettes when you pick one of these block-subassemblies from the shared palette you have to explode it before it works properly. Is anyone else finding this to be the case? Any and all help is appreciated.
Regards,
Phil
