Hello Forum members..I just want to post..where i am so far with the coding. With the help of your forum members thanks for that.
;;Error trapping
(defun error-rout (str)
 (if (/= str "Function cancelled")
     (princ (strcat "\n***ERROR***" str "***"))
 (setq *error* olderr)
 (command "-layer" "s" oldlayer "")
 (setvar "OSMODE" oldosnap)
 (setvar "CMDECHO" oldcmdecho)
;;Weld line program that draws a polyline for marking of weld signature on sheetmetal parts
(defun c:wzz ( / a d h i l n p q x y y1 y2 y3 y4 d1 n1 oldlayer oldosnap oldcmdecho)
(setq olderr *error*
     *error* error-rout)
;;Getting current Layer
(setq oldlayer  (getvar "clayer"))
;;Getting current cmdecho mode
(setq oldcmdecho (getvar "cmdecho"))
;;Getting current osmode
(setq oldosnap (getvar "osmode"))
;;setting osmode zero
(setvar "OSMODE" 32)
;;setting cmdecho zero
(setvar "cmdecho" 0)
(command "._undo" "begin")
;;Set up Layer DIGI_MARKER_TOOL_1
(if (not (tblsearch "LAYER" "DIGI_MARKER_TOOL_1"))
(Command "-layer" "n" "DIGI_MARKER_TOOL_1" "c" "70" "DIGI_MARKER_TOOL_1" "s" "DIGI_MARKER_TOOL_1" "P" "N" "DIGI_MARKER_TOOL_1" "L" "Continuous" "" "LW" "0.18" "DIGI_MARKER_TOOL_1" "")
;;Setting to created layer
(setvar "clayer" "DIGI_MARKER_TOOL_1"))
;;setting height of weld line
(setq h 20.0)
;;Machine room
(if (and
   (setq x  (getreal "\nWeld Length: "))
   (setq y1 (getreal "\nGuess a Weld length space: "))
   (setq p (getpoint "\n1st Point: "))
   (setq q (getpoint "\n2nd Point: " p))
   (setq p (trans p 1 0)
         q (trans q 1 0)
         a (angle p q)
         d (distance p q)
         i (/ pi 2.0)
        d1 (- d x)
        y3 (+ y1 x)
         n (fix (/ d1 y3))
        n1 (- n 1)
        y4 (/ d1 n)
       (if (< 0 n)
               (setq y (- y4 y3))
               (setq y2 (+ y y1))
               (repeat n
                   (setq l (cons (cons 10 p) l)
                         l (cons (cons 10 (setq p (polar p a x))) l)
                         l (cons (cons 10 (setq p (polar p (- a i) h))) l)
                         l (cons (cons 10 (setq p (polar p a y2))) l)
                         l (cons (cons 10 (setq p (polar p (+ a i) h))) l)
               (entmake
                   (append
                       (list
                          '(000 . "LWPOLYLINE")
                          '(100 . "AcDbEntity")
                          '(100 . "AcDbPolyline")
                           (cons 90 (1+ (length l)))
                          '(70 . 0)
                       (reverse (cons (cons 10 (polar p a x)) l))
           (princ "\nDistance too small.")
;;setting setting up old layer
(command "-layer" "s" oldlayer"" )
;;setting osmode to past
;;setting CMDECHO to past
But the warning if the distance between the two points is smaller then the weld length or and the weld spacing is not working. Any clues......?
Help Please!
