m-a-c-f Posted November 10, 2008 Posted November 10, 2008 Hi, Really need help to try to solve a big problem, I use Mechanical 2006, and all xref files was located on E:\ENG.EQUIP.SECCIONADORES\DESENHOS\BH..... The T.I. team, without any warnings, change the server to "I" and all drawings goes to a different locations, but the original structure remains the same in other drive, "I". Every drawing I try to open I have to manually sets the xref path. Is there any solution for this? Regards. Manoel. Quote
lpseifert Posted November 10, 2008 Posted November 10, 2008 Try using Reference Manager, can be found under Windows Start > All Programs > Autodesk... Quote
m-a-c-f Posted November 11, 2008 Author Posted November 11, 2008 Very usefull, Thanks for the tip. Regards. Manoel. Quote
