mvrcad Posted November 29, 2012 Posted November 29, 2012 (edited) Hi all this has been happening for a month or two and ive been wondering if anyone else has experienced this or knows a fix please. i insert a block into my 3d model. the block is visible in 2d wireframe then i change the shading to anything else, like realistic or 3d hidden, and the item is not visible. i have found a way around this by exploding the block, then unexploding and then for some reason it is visible. cheers Marcus Edited November 29, 2012 by mvrcad subscribed to thread Quote
Dadgad Posted November 29, 2012 Posted November 29, 2012 Are you able to view the block, which you are inserting, in the source drawing using those visualstyles? Perhaps those visualstyles were not available in the original drawing? Does it display in CONCEPTUAL or SHADED visual styles without exploding it? Quote
ReMark Posted November 29, 2012 Posted November 29, 2012 Please post a copy of one of these blocks so we can test for ourselves. Thank you. Quote
mvrcad Posted November 29, 2012 Author Posted November 29, 2012 Cheers guys I will check and reply to both posts tomorrow at work (Australia ) Quote
mvrcad Posted November 29, 2012 Author Posted November 29, 2012 Are you able to view the block, which you are inserting, in the source drawing using those visualstyles?Perhaps those visualstyles were not available in the original drawing? Does it display in CONCEPTUAL or SHADED visual styles without exploding it? yes it displays properly in its own block file Please post a copy of one of these blocks so we can test for ourselves. Thank you. 20NB90ELSW3000#.dwg Quote
nod684 Posted November 30, 2012 Posted November 30, 2012 i've tried inserting your block on a blank drawing and i didn't encounter any problem when changing visual styles Quote
SLW210 Posted November 30, 2012 Posted November 30, 2012 No problems with visibility here. What graphics card and driver? Computer specifications? Quote
mvrcad Posted December 3, 2012 Author Posted December 3, 2012 No problems with visibility here. What graphics card and driver? Computer specifications? QUATRO FX 3800 hey guys, i just played around with the graphics card accelaration settings, ie turned it on, inserted a block and seems problem solved. cheers Quote
