dirtlegg Posted November 30, 2012 Posted November 30, 2012 For civil 3d 2012...where is the symbol library??? you know, to insert like power poles, pipe symbols, gas valves, and whatnot... going to civil3d 2012 from autocad 2002 is quite a leap!!! Quote
Murph_map Posted November 30, 2012 Posted November 30, 2012 (edited) For civil 3d 2012...where is the symbol library??? you know, to insert like power poles, pipe symbols, gas valves, and whatnot... going to civil3d 2012 from autocad 2002 is quite a leap!!! They are in the styles used for those objects created in your template file(s) used to start projects. Look in this folder C:\Program Files\Autodesk\AutoCAD Civil 3D 2011\Sample\Symbols and in the dwg files there. (That's from 2011, 2012 should be the same) Also all those layers you deleted may of have them already in the dwg and available. Edited November 30, 2012 by Murph_map added line Quote
