fawellp Posted December 1, 2012 Posted December 1, 2012 Do you recommend VBA or Lisp for following project? https://www.elance.com/j/vba-macros-lisp-routine-3d-solid-modelling-autocad/35665239/ Please let me know if you have the time / expertise to compelte the project! VBA Macro or Lisp routine for AutoCAD.docx Quote
fixo Posted December 2, 2012 Posted December 2, 2012 I think Lisp will be more preferable to such task Quote
SEANT Posted December 2, 2012 Posted December 2, 2012 I agree with fixo; VBA has questionable long term viability. Stick with Lisp of those two. Or, at least specify VB.NET and/or the other .NET variants. Quote
fawellp Posted December 2, 2012 Author Posted December 2, 2012 Thank you fixo/seant that's very useful advice. Quote
fixo Posted December 2, 2012 Posted December 2, 2012 (edited) Here you will be started, just a scratch, sorry (defun C:ww(/ ) (setvar "cmdecho" 0) (setvar "selectionpreview" 3) (command "_ucsicon" "_off" ) (command "_ucsfollow" 0 ) (setvar "osmode" 1) (setq pt (getpoint "\nSpecify new origin point of UCS: ")) (command "_zoom" "_c" pt (/ (distance (getvar "extmax")(getvar "extmin"))2.)) (command "_-view" "_seiso") (setvar "osmode" 512) (setq px (getpoint "\nSpecify point on positive portion of X-axis: ")) (setq py (getpoint "\nSpecify point on positive-Y portion of the UCS XY plane: ")) (command "_ucs" "_3p" pt px py) (setvar "osmode" 512) ;;dummy values used: (setq wp (getpoint pt "\nPick next point: ")) (setq w1 (list (car wp)(cadr wp)(+ (caddr wp) 750.)) w2 (list (+ (car w1)1350.)(cadr w1)(caddr w1)) w3 (list (car w2)(cadr w2)(+ (caddr w2) 2100.)) w4 (list (car w1)(cadr w1)(caddr w3))) (setq wall (ssname (ssget "_C" pt wp (list (cons 0 "3dsolid")))0)) (command "_box" "_non" w1 "_non" (list (car w2)(+ (cadr w2)10000.)(caddr w2)) 1350.0);;10000. is dummy value to subtract box (setq tmpsol (entlast)) (command "_subtract" wall "" tmpsol "" ) (command "_ucsicon" "_on" ) (command "_ucs" "_p") (setvar "cmdecho" 1) (princ) ) Edited December 2, 2012 by fixo Quote
