CAD911
Adding Flange To Twisted Sheet Metal Part
CAD911
Using Inventor 2013
I cant to add a flange to a slightly twisted sheet metal part. I created the part by lofting between two lines from a 3d sketch. Then thickened to my sheet metal default thickness. Then i coverted part to sheet metal. I can create a flat pattern. I am trying to add the flange to one of the straight edges that the loft was created from. There is no twist on this edge.
I also need flanges on the twited sides but for now the straight sides will do. I also tried to unfold thinking i could add the flanges and refold but i cant unfold the twisted part.
Thanks any help would be great.
Share this post
Link to post
JD Mather
Attach ipt file here.
Do not use standard Loft.
Use the sheet metal Loft.
Share this post
Link to post
CAD911
ok will post in 5 min
I see the lofted flange command?
Thanks
Share this post
Link to post
CAD911
I figured it out
Thank You
Share this post
Link to post
