jdofboise Posted December 6, 2012 Posted December 6, 2012 The routine below Will create a new UCS and Ordinate dimension and then begin the ordinate command. I've created 4 seperate routines to handle 2 different UCS locations with 2 different Dimstyles for each UCS. One Dimstyle being all red and the other being bylayer. Currently when I run the routine for UCS "A" it works fine. The problems start when I run the routine for UCS "B". Since the UCS is now 0,0 at UCS "A" the routine sets the UCS "B" to a location relative to UCS "A" and not the lower left hand corner of the border. I can't figure out how to reset the UCS back to the drawings original UCS ("World" or 0,0 of border) after using the command so I can run each routine at any given time and land at my specified UCS's. How do I reset the Original border UCS to then reset my 2nd new UCS? I've tried... (if (tblsearch... at the beginning just after the first setvar. or (commmand "ucs" "World")...in the same place or (command "ucs" "World")...at the bottom below the last (command... No favorable results. Should I create both new UCS' in the same routine so that it exists as a known point relative to the sht. border? I just can't see it. (defun c:frd (/ scmde RedOrd) (setq scmde (getvar "cmdecho")) (setvar "cmdecho" 0) (if (tblsearch "UCS" "PnlFront") (command "_ucs" "restore" "PnlFront") (progn ;;(command "_ucs" "restore" "World") (command "_ucs" "New" "236.3125,68.00,0.0") (command "_ucs" "Named" "Save" "PnlFront") (command "_ucs" "Restore" "PnlFront") (command "_ucsicon" "on" "" "ORigen") ) ) (if (tblsearch "DimStyle" "Red_Ordinate") ; if Red_Ordinate exists, (command "DimStyle" "Restore" "Red_Ordinate") ; activate DimStyle (progn (setvar "DIMADEC" 0) (setvar "DIMALT" 0) (setvar "DIMALTD" 2) (setvar "DIMALTF" 25.4000) (setvar "DIMALTRND" 0.0000) (setvar "DIMALTTD" 2) (setvar "DIMALTTZ" 0) (setvar "DIMALTU" 2) (setvar "DIMALTZ" 0) (setvar "DIMAPOST" "") (setvar "DIMASSOC" 1) (setvar "DIMASZ" 0.1250) (setvar "DIMATFIT" 3) (setvar "DIMAUNIT" 0) (setvar "DIMAZIN" 0) (setvar "DIMBLK" "") (setvar "DIMBLK1" "") (setvar "DIMBLK2" "") (setvar "DIMCEN" 0.0938) (setvar "DIMCLRD" 1) (setvar "DIMCLRE" 1) (setvar "DIMCLRT" 1) (setvar "DIMDEC" 2) (setvar "DIMDLE" 0.0000) (setvar "DIMDLI" 0.3750) (setvar "DIMDSEP" ".") (setvar "DIMEXE" 0.0938) (setvar "DIMEXO" 0.1250) (setvar "DIMFIT" 3) (setvar "DIMFRAC" 2) (setvar "DIMGAP" 0.0625) (setvar "DIMJUST" 0) (setvar "DIMLDRBLK" "") (setvar "DIMLFAC" 1.0000) (setvar "DIMLIM" 0) (setvar "DIMLUNIT" 5) (setvar "DIMLWD" -2) (setvar "DIMLWE" -2) (setvar "DIMPOST" "\"") (setvar "DIMRND" 0.0000) (setvar "DIMSAH" 0) (setvar "DIMSCALE" 8.0000) (setvar "DIMSD1" 0) (setvar "DIMSD2" 0) (setvar "DIMSE1" 0) (setvar "DIMSE2" 0) (setvar "DIMSHO" 1) (setvar "DIMSOXD" 0) (setvar "DIMTAD" 0) (setvar "DIMTDEC" 4) (setvar "DIMTFAC" 1.0000) (setvar "DIMTIH" 0) (setvar "DIMTIX" 1) (setvar "DIMTM" 0.0000) (setvar "DIMTMOVE" 0) (setvar "DIMTOFL" 0) (setvar "DIMTOH" 0) (setvar "DIMTOL" 0) (setvar "DIMTOLJ" 1) (setvar "DIMTP" 0.0000) (setvar "DIMTSZ" 0.0000) (setvar "DIMTVP" 0.0000) ;;(setvar "DIMTXSTY" "DIMEN") ;;(setvar 4 . "\"") (setvar "DIMTXT" 0.1250) (setvar "DIMTZIN" 0) (setvar "DIMUNIT" 7) (setvar "DIMUPT" 0) (setvar "DIMZIN" 3) (command "_.-dimstyle" "Save" "Red_Ordinate") (command "_.-dimstyle" "Restore" "Red_Ordinate") ) ) (command "dimordinate") (princ) ) ;end defun Thanks for taking the time. JD Quote
MSasu Posted December 6, 2012 Posted December 6, 2012 Using TRANS function you may transform the coordinates from one coordinates system to another: (setq point1st (getpoint) point2nd (getpoint)) (command "_UCS" point1st "" "") (command "_UCS" (trans point2nd 0 1) "" "") Not sure why reseting the UCS to WCS doesn't work; I will try to have a look on your code later. Quote
