JENKAT Posted December 11, 2012 Posted December 11, 2012 I'm using AutoCAD 2013 and it will not convert a p-line to revcloud, any suggestion on how to get this to work. Quote
SLW210 Posted December 11, 2012 Posted December 11, 2012 What is displayed on the command line when you attempt this? Quote
JENKAT Posted December 11, 2012 Author Posted December 11, 2012 It prompts to start cloud /arc length but does not give the option to pick the object. Quote
SAFeSTeR Posted December 12, 2012 Posted December 12, 2012 After you started the revcloud command did you type 'O' to tell it to select an object? Quote
JENKAT Posted December 13, 2012 Author Posted December 13, 2012 No it's not a new install. It does not let me pick and object. It goes straight to arc length/pick starting point. Quote
ReMark Posted December 13, 2012 Posted December 13, 2012 Did the command ever function correctly? Command: REVCLoud Minimum arc length: 0.1250 Maximum arc length: 0.1250 Style: Normal Specify start point or [Arc length/Object/Style] : This is the default in my version of AutoCAD 2013. Your version operates differently? Quote
pqphillips Posted December 13, 2012 Posted December 13, 2012 Maybe he's not looking at the command line to see that. ACADE has an issue with the command line defaulting as a floating toolbar instead of being docked traditionally... Quote
ReMark Posted December 13, 2012 Posted December 13, 2012 Are there any other commands that don't work as expected? Seems odd if this were the only one. You could try a REPAIR of the installation. Quote
pqphillips Posted December 13, 2012 Posted December 13, 2012 Yeah, you're gonna want to do a repair or a flat out reinstall... Quote
SLW210 Posted December 13, 2012 Posted December 13, 2012 Can you post some screenshots or a Copy/Paste of your commandline history (F2) when you attempt these commands? Sounds like you may have an older custom LISP routine for RevCloud that is starting instead of the one included in AutoCAD RevCloud. Quote
JENKAT Posted December 13, 2012 Author Posted December 13, 2012 We came to that same conclusion. We have some custom lisp routine from the past. We are now looking in to it. Thanks Quote
