Windows 7 and Zip Function for Project
Hi all, new here. I tried searching but couldn't come up with an answer.
I'm running Win7 64 bit, AutoCAD 2012 with Electrical 2012. I went to zip a project, and came up with "no zip program found" I started looking at the env file, but wasn't sure what to do. I don't have winzip or winrar or anything like that installed. Just the zip function built into windows. Is this something that is usable?
Thanks so much for the help.
thanks, i already knew how to use windows functions to zip a set of files.
what i was asking for was using the zip utility embeded inside autocad electrical. when i go to the projects tab, and click on zip, i get an error stating that a zip utility is not installed. I needed to modify the .env (i think) file to show the location of the zip utility.
because windows 7 has native zipping functionality, i am unsure what to put, so that i can zip the project.
