Eigil Posted December 12, 2012 Posted December 12, 2012 Hello I'm looking for a way to change the colors of an object based on the objects material. What I've learned is that the objects (or enteties? I mean mesh/solid/face or similar) consists of colors, materials and textures. If every mesh had its color I would run this script I've found called COL2LAY which puts everything on different layers based on their indexcolor. The reason for this is that I need texturize everything in a another Autocad application called Novapoint, and this texturizing is based on layers (I know it sounds inconvinient, it is!) I'm importing skp files from google warehouse with the autodesk plug-in "skp-import" and my dwg-models have material and texture, but everything is on layer 0 and color white or bylayer.. What makes it more difficult is that parts of the object have material "byblock".. I really apprieciate help! Sorry for my awkward english:oops: Quote
irneb Posted December 13, 2012 Posted December 13, 2012 Welcome to Cad Tutor. Each entity with a material applied to it would have a 347 DXF code. This contains the ename referring to the material record in the materials dictionary. So you can then use the 1 dxf code to get that material's name. From there it's much the same as the col2lay function. About the byblock material, that's a near impossible "fix". What happens if there are 2 copies of the same block, but different materials? You'd need to explode the blocks and apply the material individually to each. Quote
Eigil Posted December 13, 2012 Author Posted December 13, 2012 Thank you for replying. I found another way around this. I export the dwg to FBX and import the FBX back into dwg. Then every mesh with material will have a color which looks similar to the material. Meshes with material byblock also seems to be dissolved into seperate colors, each color similar to the material. Quote
irneb Posted December 13, 2012 Posted December 13, 2012 That does seem a lot simpler yes. I was looking for something older (i.e. export to 3DS) which had similar functionality, but it seems ACad 2013 can't export to 3DS any-more. Quote
