svrkjg Posted December 12, 2012 Posted December 12, 2012 Hello All, I have an issue with a drawing created in AutoCad 2002. Whenever I open it to edit it and then either Print or Save it shows Scanning Drawing and takes considerable amount of time for this process. I have done a purge so far but that did not help. Any suggestions? Best Regards KenJG Quote
Cad64 Posted December 12, 2012 Posted December 12, 2012 Run an AUDIT to check for errors in the drawing file. Quote
svrkjg Posted December 13, 2012 Author Posted December 13, 2012 Hello Cad64, Thank you much for your reply. I seem to find a fix, using WBLOCK. But not sure if this needs to be done all the time with drawings with the same issue. Keep up the good work. BR Kenjg Quote
