Hi,
How do you start the numbering on multi text from a No. higer than 1?
I got it to work once using the "Continue" option under "Bullets and Lists". It's a bit tricky.
Copy and paste works, but is a bit of a pain. I.e. make a 10 number list. Then you can copy numbers 5 to 10 to a new mtext entity and the numbering bullet points remain, starting at 5.
