ksperopoulos Posted December 15, 2012 Posted December 15, 2012 I am trying to find a way to view a list of an object's properties to use while trying to develop a lisp. I feel like I am looking in every place except the correct one. Can anyone point me in the right direction? Thanks for any help you can give. Quote
Lee Mac Posted December 15, 2012 Posted December 15, 2012 You can view the list of available ActiveX Properties & Methods for an object (including the number of parameters required by each method) by passing the VLA-Object to the vlax-dump-object function. You can also view the entire AutoCAD Object Model, including a list of Properties & Methods for every object (and documentation for each Property / Method) in the ActiveX Developer Documentation (found in the acadauto.chm file, or made available online here). Quote
BIGAL Posted December 16, 2012 Posted December 16, 2012 Heres the lisp for dump object ;;;===================================================================; ;;; DumpIt ; ;;;-------------------------------------------------------------------; ;;; Dump all methods and properties for selected objects ; ;;;===================================================================; (defun C:DumpIt ( / ent) (while (setq ent (entsel)) (vlax-Dump-Object (vlax-Ename->Vla-Object (car ent)) ) ) (princ) ) Quote
Tharwat Posted December 16, 2012 Posted December 16, 2012 ;;; DumpIt ;;; Dump all methods and properties for selected objects That gives only Properties and to get methods as well , you should add T to the function Vlax-Dump-object Quote
