dirtlegg Posted December 18, 2012 Posted December 18, 2012 My civil 3d all of a sudden is not browsing with explorer when i use the open or save command...it goes to the command prompt and wants me to type the path in...anyone know what is going on??? Quote
dirtlegg Posted December 18, 2012 Author Posted December 18, 2012 Thank you!! Where can I find a library of these System Variables?? Quote
ReMark Posted December 18, 2012 Posted December 18, 2012 You can obtain a list of all the variables and what their current settings are by running vars2scr at the command line. This will write a script file (give it a recognizable name) with the file extension .scr to your hard drive at a location (folder/desktop/other) that you specify. This script file can be run in the future to reset your system variables. Quote
rkmcswain Posted December 18, 2012 Posted December 18, 2012 Thank you!! Where can I find a library of these System Variables?? In HELP. Start Here: http://exchange.autodesk.com/autocad/enu/online-help/browse#WSfacf1429558a55de6d0beb1006696e53b-6076.htm Quote
Emigrato Posted December 18, 2012 Posted December 18, 2012 Sometimes "Filedia" must stay set to 0, for instance during a script routine. As an undocumented feature, you can pop up the normal GUI window, issueing ~ at the prompt. Quote
rkmcswain Posted December 18, 2012 Posted December 18, 2012 In Express Tools > System Variables You can obtain a list of all the variables and what their current settings are by running vars2scr at the command line In most cases, these will suffice. But both of these methods omit some variables. The former uses a file, "sysvdlg.dat" to populate the dialog, and I'm not sure about the latter, but it is incomplete too. Another source that I believe to be complete is here: http://www.hyperpics.com/system_variables/index.asp Quote
ReMark Posted December 18, 2012 Posted December 18, 2012 What about using acadinfo.lsp instead although it does contain way more additional information than most users (99.9%?) might ever need? Quote
