seems like you are trying to draw 3d dimension line without changing UCS... if so ... great idea. I d love to see it work
  • Replies 21
  • popey3
    8
  • CADWarrior
    6
  • David Bethel
    2
  • Lee Mac
    2
hey! i made the code i wanted to get with this thread and would like to present it for you guys:
(princ "
frame;;Draw the frame for the entire drawing")
(defun c:frame ( / corner1 corner3 F1 Frame0 )
 (setq corner1 (list -15.5 15 0))
 (setq corner3 (list 5.5 -14 0))
 (command "rectangle" corner1 corner3)
 (setq F1 (entlast))
 (setq Frame0(vlax-ename->vla-object F1))
;;Define the coordinates of point A and draw it
(princ "
drawA;;Define the coordinates of point A and draw it")
(defun c:drawA ( / Axx Ayy Azz)
 (setq pointA (getpoint "\nSpecify Point A: "));;Asks user to specify point
 (setq Axx (nth 0 PointA)) 			;;selects the 1st variable in the list pointA
 (setq Ayy (nth 1 PointA)) 			;;selects the 2nd variable in the list pointA
 (setq Azz (nth 2 PointA)) 			;;selects the 3rd variable in the list pointA
 (setq A1 (list (* Axx -1) (* -1 Ayy) 0.0))	;;sets coords for p on plane (x-y)
 (setq A2 (list (* Axx -1) Azz 0.0))		;;sets coords for p on plane (x-z)
 (command "insert" "tA1" A1 1 1 0)		;;inserts the mark for P on plane (x-y)
 (command "insert" "tA2" A2 1 1 0)		;;inserts the mark for P on plane (x-z)
;;Define the coordinates of point B
(princ "
DrawB;;Define the coordinates of point B")
(defun c:DrawB ( / Bxx Byy Bzz)
 (setq pointB (getpoint "\nSpecify Point B: "));;Asks user to specify point
 (setq Bxx (nth 0 PointB)) 			;;selects the 1st variable in the list pointB
 (setq Byy (nth 1 PointB)) 			;;selects the 2nd variable in the list pointB
 (setq Bzz (nth 2 PointB))			;;selects the 3rd variable in the list pointB
 (setq B1 (list (* Bxx -1) (* -1 Byy) 0.0))	;;sets coords for T on plane (x-y)
 (setq B2 (list (* Bxx -1) Bzz 0.0))		;;sets coords for T on plane (x-z)
 (command "insert" "tb1" B1 1 1 0)		;;inserts the mark for T on plane (x-y)
 (command "insert" "tb2" B2 1 1 0)		;;inserts the mark for T on plane (x-z)
;;draw the line on (X-Y)
(princ "
funkp1;;draw the line on (X-Y)")
(defun c:funkp1 ( / ax ay az bx by bz)
 (setq ax (car A1))
 (setq ay (cadr A1))
 (setq az (cadr A2))
 (setq bx (car B1))
 (setq by (cadr B1))
 (setq bz (cadr B2))
 (setq Dy1 (- by ay))
 (setq Dx1 (- bx ax))
 (setq K1 (/ Dy1 Dx1))
 (setq N1 (- ay (* ax K1)))
 (setq edgeX1 -13)
 (setq edgeY1 (+ N1 (* K1 edgex1)))
 (setq edge1 (list edgex1 edgey1 0.0))
 (setq edgeX2 3)
 (setq edgeY2 (+ N1 (* K1 edgeX2)))
 (setq edge2 (list edgex2 edgey2 0.0))
 (entmake (list (cons 0 "LINE")(cons 10 edge1)(cons 11 edge2)))
;;draw the line on (X-Z)
(princ "
funkp2;;draw the line on (X-Z)")
(defun c:funkp2 ( / ax ay az bx by bz)
 (setq ax (car A2))
 (setq ay (cadr A2))
 (setq az (cadr A2))
 (setq bx (car B2))
 (setq by (cadr B2))
 (setq bz (cadr B2))
 (setq Dy2 (- by ay))
 (setq Dx2 (- bx ax))
 (setq K2 (/ Dy2 Dx2))
 (setq N2 (- ay (* ax K2)))
 (setq edgeX3 -13)
 (setq edgeY3 (+ N2 (* K2 edgex3)))
 (setq edge3 (list edgex3 edgey3 0.0))
 (setq edgeX4 3)
 (setq edgeY4 (+ N2 (* K2 edgeX4)))
 (setq edge4 (list edgex4 edgey4 0.0))
 (entmake (list (cons 0 "LINE")(cons 10 edge3)(cons 11 edge4)))
i have some more ideas that i want to put into it, but i'm content with this for now. The new stuff will include mostly object snapping from these points, so i will read up on referencing objects before continuing. thanks for the help!
