motee-z Posted December 24, 2012 Posted December 24, 2012 Here is my lisp use it several years ago it works fine clothoid.LSP Quote
venkat241 Posted January 27, 2013 Posted January 27, 2013 Thank you very much for sharing the lisp. It works very finely. Also request you to share Parabolic curve lisp if any for plotting the Summit or Valley curve between two grades (lines) in the same lines as clothoid lisp having options like 1. Length of the curves, select grade1 and grade2, 2. K value, select grade1 and grade2. Aslo request you to have option vertical exaggeration/magnification scale. Regards MVRAO Quote
sudipta_1986 Posted September 7, 2013 Posted September 7, 2013 please tell me the command after loading the lisp file Quote
Tharwat Posted September 7, 2013 Posted September 7, 2013 please tell me the command after loading the lisp file Welcome to Cadtutor . The text which is after the c: at the top of the routine must be the command name . Quote
Tharwat Posted September 7, 2013 Posted September 7, 2013 thanks @ tharwat You're welcome . All credit goes to motee-z of course . Quote
ur_naz Posted September 7, 2013 Posted September 7, 2013 This lisp does not working in localized acad Quote
marinhoh Posted June 30, 2014 Posted June 30, 2014 This is the best lisp for transition curves, thanks man! Quote
fatolahi Posted January 10, 2016 Posted January 10, 2016 this lisp does not work. After I load this lisp in CAD, and type the lisp name, the name doesn't exist. Quote
motee-z Posted January 10, 2016 Author Posted January 10, 2016 you have to type kloto after loading lisp Quote
