Wolfsong Posted December 29, 2012 Posted December 29, 2012 hi, First of all, this is my first post and i would like to say hello to everybody. My issue is that all my rounded objects aren´t rendering smooth. And what is up with all these lines? Am i missing something when i render rounded objects? I already tried the this tip but nothing changed. Can anyone help me to solve this issue? Greetings. Quote
the downing effect Posted January 1, 2013 Posted January 1, 2013 Looks a little different then the problem I was having but under options>display there are settings for display resolution. I bump it way up to 10000, 500, 10, 500 sometimes even more, probably overkill, then make sure to 'regenall', and it should look alot better. If that doesn't get rid of the lines as well try going to the view tab, then under visual styles change it to no edges. There are some real experts around that can help more, but hopefully that will get you going. Quote
Dadgad Posted January 1, 2013 Posted January 1, 2013 Welcome to CADTutor. Try setting DISPSILH to 1, to get rid of the lines. Quote
JD Mather Posted January 1, 2013 Posted January 1, 2013 If viewres, facetres, dispsilh and regen don't solve the problem - attach the file here. Quote
Cad64 Posted January 1, 2013 Posted January 1, 2013 Were those objects created in Autocad or imported from another program? Quote
ReMark Posted January 2, 2013 Posted January 2, 2013 When you say your objects aren't "rendering smooth" are you referring to the fact that the circles appear to be made up of short line segments (i.e. - not round)? Quote
JD Mather Posted January 3, 2013 Posted January 3, 2013 Assignment must have been past due. On off chance that 1-post Wolfsong returns - what entity type(s) does List command say you have? Quote
