brl2008 Posted January 2, 2013 Posted January 2, 2013 Hi to all I'm working on a drawing that 4 or 5 xred plus line the file about 3,660kb. So when I do a Qsave I get these message (MULTIPLY OWNED OBJECT, HANDLE "38920E"), It saves for me but does take some time. Does anyone understand the message or just don't planic yet. thank all that reply brl2008 Quote
brl2008 Posted January 7, 2013 Author Posted January 7, 2013 SLW210 thanks for the reply i did not get the "see if THIS helps" at first, how the moment is gone. i read the blogs and try what said to do, did not have much like with what there said to do. i will look at some more blogs later to see if can find code#38920E thanks again for the help brl2008 Quote
rkent Posted January 7, 2013 Posted January 7, 2013 So you tried typing (entdel(handent"38920E")) at the command line in that drawing? Quote
brl2008 Posted January 9, 2013 Author Posted January 9, 2013 will I thought I did, but looking what I wrote down and type in where 2 different things. So did it again the right way and got the message Entity Name: 4ffa260are07. not sure if it work i did a QSAVE and did not get the warming message that recieved before. New question-if I get another warming maessage with a number at the end can i type in (entdel(handent"#####")) to make it go away? thanks for the reply rkent & SLW210 brl2008 Quote
SLW210 Posted January 10, 2013 Posted January 10, 2013 As Far As I Know, only *WARNING*(MULTIPLY OWNED OBJECT, HANDLE "######") can be solved with (entdel(handent"#####")). Though... handentReturns an object (entity) name based on its handle If successful, handent returns the entity name associated with handle in the current editing session. If handent is passed an invalid handle or a handle not used by any entity in the current drawing, it returns nil. The handent function returns entities that have been deleted during the current editing session. You can undelete them with the entdel function. An entity's name can change from one editing session to the next, but an entity's handle remains constant. entdelDeletes objects (entities) or restores previously deleted objects Quote
