NoelStalker Posted November 11, 2008 Posted November 11, 2008 Is it possible to access the find command from the command line and input your search text in the command line instead of in the dialog box? I tried -find _find and .find and those didn't work. I want to manipulate the find and replace command with a lisp and I don't know how to do that with dialog boxes. Quote
fuccaro Posted November 11, 2008 Posted November 11, 2008 As a walkaround you could explore the WCMATCH lisp function. In the Help file it says nothing about a command line version (as it says for other commands), so probable you are out of luck this time. Quote
NoelStalker Posted November 11, 2008 Author Posted November 11, 2008 fuccaro, What is the wcmatch lisp? It apparently isn't bundled with my version of ACAD (2005) because I typed it and nothing happened. Quote
dbroada Posted November 11, 2008 Posted November 11, 2008 I haven't found a way yet. I have written a VBA routine to do similar things but don't have it at home. Quote
fuccaro Posted November 11, 2008 Posted November 11, 2008 fuccaro,What is the wcmatch lisp? It apparently isn't bundled with my version of ACAD (2005) because I typed it and nothing happened. (wcmatch string pattern) Arguments string A string to be compared. The comparison is case-sensitive, so uppercase and lowercase characters must match. pattern A string containing the pattern to match against string. The pattern can contain the wild-card pattern-matching characters shown in the table Wild-card characters. You can use commas in a pattern to enter more than one pattern condition. Only the first 500 characters (approximately) of the string and pattern are compared; anything beyond that is ignored. Both arguments can be either a quoted string or a string variable. It is valid to use variables and values returned from AutoLISP functions for string and pattern values. Return Values If string and pattern match, wcmatch returns T; otherwise, wcmatch returns nil. it must be in 2005 too! Quote
NoelStalker Posted November 12, 2008 Author Posted November 12, 2008 fuccaro, Thanks! I understand how this could help me find matching strings. How would I be able to replace what I found with a new string? Quote
fuccaro Posted November 12, 2008 Posted November 12, 2008 Use the SUBSTR to cut the string in pieces and STRCAT to join them back. Ofcourse you will replace the unwanted pieces with your own strings. Quote
cadvision Posted November 13, 2008 Posted November 13, 2008 This is an old release 12 find/replace lisp: ;;; REPTEXT.LSP 3.xx is a substantially rewritten version compared to ;;; version 2.xx. Please see the * HISTORY * section below. ;;; REPTEXT.LSP is an AutoCAD Release 12 utility to search & replace ;;; text items in a drawing, including within block definitions, ;;; dimensions, and attributes. It will also process these entities in ;;; nested blocks to any depth. ;;; This routine can be used to search for all or selected instances of ;;; a particular text string, and replace them with a different string. ;;; This is most useful for global replacement of references, phrases, ;;; and control codes. As an example, this routine could be used to ;;; replace the old Release 10-style %%127, 128 and 129 control codes, ;;; with the later %%d, %%p and %%c codes respectively. ;;; * USAGE * ;;; After loading the routine (eg. (load "reptext")) and executing by ;;; typing REPTEXT at the Command: prompt, there are only five or six ;;; prompts to respond to. First you will be asked to specify the text ;;; string to search for, and the string to replace it with. Both can ;;; contain spaces. The search string is not case sensitive. ;;; You are then asked what entity types you wish to process. These can ;;; be normal text, dimension user-supplied text, blocks (containing any of ;;; the other entity types, including nested blocks), and block attribute ;;; values. If you respond with Y or Yes to any of these, any relevant ;;; selected entities will be processed. Responding Y or Yes to blocks ;;; will also ask if attribute values are to be processed. A negative ;;; answer to all entity types will repeat the prompt sequence. ;;; Lastly, you are asked to select the entities to modify. You can do ;;; this with any of the normal AutoCAD entity selection methods (including ;;; ALL, to process the entire drawing). REPTEXT will filter out the ;;; required entities. ;;; The routine will then start processing - you will see text entities ;;; being dynamically altered on screen. Block definitions will be ;;; regenerated on screen after processing is complete. Have fun! ;;; Peter J T Heald, Autodesk UK Ltd. ;;; Tech are the biz. ;;; * HISTORY * ;;; The main changes between version 2.xx and this version are as follows: ;;; Associative dimensions will not loose their updated text values ;;; during stretching and moving. ;;; Block attribute values will now be processed. ;;; Dimensions, text, blocks & attributes within blocks will now be ;;; processed no matter what the level of nesting. ;;; The main reason for rewriting was because version 2.xx was pretty naf. ;;; Notation will be added to the code at some stage, when I have time... ;;; Any comments or suggestions relating to this routine are most welcome. ;;; THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED ;;; WARRANTY. ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR ;;; PURPOSE AND OF MERCHANTABILITY ARE HEREBY DISCLAIMED. (prompt " REPTEXT.LSP by P.Heald Sept'92-Apr'93 Ver. 3.01\n") ;;; Global variables are: blist oldtxt newtxt txttoo dimtoo blktoo atttoo (defun c:reptext ( / sslist ss count en bllen bdata nen) (setvar "cmdecho" 0) (setq oldtxt (getstring T "\nText to search for: ") newtxt (getstring T "\nReplace with: ") txttoo F dimtoo F blktoo F ) (while (not (or txttoo dimtoo blktoo)) (prompt "\nSelect desired operation.") (initget "Yes No") (setq txttoo (getkword "\nProcess normal text? : ") sslist '((-4 . " ) (if (= txttoo "No") (setq txttoo F) (setq sslist (append sslist '((0 . "TEXT"))) txttoo T ) ) (initget "Yes No") (setq dimtoo (getkword "\nProcess dimensions? : ")) (if (= dimtoo "Yes") (setq sslist (append sslist '((0 . "DIMENSION")))) (setq dimtoo F) ) (initget "Yes No") (setq blktoo (getkword "\nProcess blocks? : ")) (if (= blktoo "Yes") (progn (initget "Yes No") (setq sslist (append sslist '((0 . "INSERT"))) atttoo (getkword "\nProcess attributes? : ") ) ) (setq blktoo F) ) (if (/= atttoo "Yes") (setq atttoo F)) ) (setq sslist (append sslist '((-4 . "OR>"))) ss (ssget sslist) count 0 blist (list) ) (prompt "\nProcessing:-\n") (repeat (sslength ss) (setq en (ssname ss count) count (1+ count) ) (entscan en oldtxt newtxt) (prompt (strcat "\r" (itoa count) " done.")) ) (prompt "\rDone ") (setq count 0 bllen (length blist) ) (if (> bllen 0) (prompt "\nProcessing blocks:-\n")) (while (and (> bllen 0) (setq bname (nth count blist))) (setq count (1+ count) bdata (tblsearch "BLOCK" bname) nen (cdr (assoc -2 bdata)) ) (while (and nen (/= (cdr (assoc 0 (entget nen))) "ENDBLK") ) (entscan nen oldtxt newtxt) (setq nen (entnext nen)) ) (prompt (strcat "\r" (itoa count) " done.")) ) (prompt "\rDone ") (if (or dimtoo blktoo) (progn (prompt "\nRegenerating drawing.") (command ".regen") ) ) (princ) ) (defun entscan (en oldtxt newtxt / ed et 2f tmp) (setq ed (entget en) et (cdr (assoc 0 ed)) 2f (cdr (assoc 2 ed)) ) (cond ((and (= et "TEXT") txttoo) (swaptext en oldtxt newtxt)) ((and (= et "DIMENSION") dimtoo) (progn (swaptext en oldtxt newtxt) (if (setq tmp (chklist blist 2f)) (setq blist tmp) ) ) ) ((and (= et "INSERT") blktoo) (progn (if (setq tmp (chklist blist 2f)) (setq blist tmp) ) (if (and atttoo (cdr (assoc 66 ed))) (attscan en oldtxt newtxt) ) ) ) ) ) (defun attscan (ename otxt ntxt / edata parent etype) (setq edata (entget ename) parent edata etype "INSERT" ) (while (and ename (/= etype "SEQEND")) (setq ename (entnext ename)) (if ename (setq edata (entget ename) etype (cdr (assoc 0 edata)) ) ) (if (= etype "ATTRIB") (swaptext ename otxt ntxt)) ) (entmod parent) ) (defun swaptext (ename otxt ntxt / edata oldt newt edata) (setq edata (entget ename) oldt (assoc 1 edata) ) (if oldt (progn (setq newt (cons 1 (swapstr (cdr oldt) otxt ntxt)) edata (subst newt oldt edata) ) (entmod edata) ) ) ) (defun swapstr (line oldstr newstr / charpos oldlen) (setq oldlen (strlen oldstr) oldstr (strcase oldstr) charpos 1 ) (repeat (1+ (- (strlen line) oldlen)) (if (= (strcase (substr line charpos oldlen)) oldstr) (setq line (strcat (substr line 1 (1- charpos)) newstr (substr line (+ charpos oldlen)) ) charpos (+ charpos (strlen newstr)) ) ) (setq charpos (1+ charpos)) ) (setq line line) ) (defun chklist (itemlist itemname) (if (member itemname itemlist) (setq itemlist F) (setq itemlist (append itemlist (list itemname))) ) ) (princ) ; - - - - - - - - - - - - - - - - - - - End Quote
NoelStalker Posted November 24, 2008 Author Posted November 24, 2008 cadvision This is a great routine. Unfortunately, it doesn't work for me because it doesn't edit mtext, apparently. Quote
cadvision Posted November 24, 2008 Posted November 24, 2008 I have a solution for your MTEXT. Explode! I'm not a huge fan of MTEXT. I get pissed off when I find single lines of text in drawings done with MTEXT. Quote
asos2000 Posted December 31, 2008 Posted December 31, 2008 when explode MTEXT there are some characters comes in a separate text like (1.25) . when explode comes in 4 lines (, 1.25, ) and . Quote
todouble22 Posted November 5, 2009 Posted November 5, 2009 I've been working on a find and replace text lisp for use at work. I want it to be able to search for strings of old text and replace them with the new desired text. Basically a find and replace that I can automate to run through a folder of drawings with a batch file. In advance I appreciate all assistance regarding this. Quote
rustym Posted November 6, 2009 Posted November 6, 2009 Not sure if this is what you looking for: I found it some where, can't remember where. It do have a dialog box as well but after uploading the lsp you can use the scr file and do a find and replace that way, by drag & drop. todouble22 , think this should work perfect for you. mfind.zip Quote
todouble22 Posted November 9, 2009 Posted November 9, 2009 rustym, thank you for that I have found that before as well but have not been able to get it to run? I'll try it again with this file maybe the one I had was different? Quote
