Insert a ladder sideways?
By this, I mean having the ladder rungs going from left to right instead of top to bottom.
Is this possible?
Drawing Properties > Drawing Format tab > Ladder Defaults" Vertical and Horizontal are both listed.
Drawing Properties can be accessed via the Ribbon (Schematic tab > Other Tools panel) or via the command prompt ( aeproperties ). I think you can also pull it up via the right-click menu if you click on the drawing name in the Project Manager.
