Hi,
I am trying to copy some object from drawing but it's saying Copy to Clipboard failed!
need some help here!!
Have updates/service packs been installed?
What program was used to create the drawing originally?
Is this happening in just one particular drawing or in any drawing you work on?
What exactly were you trying to copy?
It's possible I have the same problem, only without the warning. I'll use Copy with Base Point in one drawing. When I go to another drawing, Paste is sometimes grayed out, as if the Copy never happened. So far I haven't found a common factor, it seems random. Typically I'm working with two drawings based on our own template. The selection set usually consist of a few simple objects, such as lines.
Hi,
I had this issue and resolved it with the "Audit" command
