What method will you choose to create 3D solids and surfaces
from existing objects in autocad?
First: Welcome to the forum!
Second: You may want to, or at least concider to, use a proper subject for the topic you start. In case you did not notice, it is all about AutoCAD.
Maybe you can start with extrude?
Some of your options are Extrude, Sweep and PressPull. Depending are what it is you are drawing 3D content can be created using the Polysolid command. There are other commands that can be used on surfaces to create solids as well.
What type of drawing are we talking about?
Do you know how to switch to the 3D Workspace?
