russell84 Posted November 12, 2008 Posted November 12, 2008 Hey guys i'm keen to make a simple program to run different vba commands etc. I'd like to be able to compile everything into a .EXE file that can be installed on peoples pc. Has anyone done this before?? If so would you be able to point me in the correct direction ie, websites - material - code language anything would be a massive help. Thanks heaps Quote
borgunit Posted November 12, 2008 Posted November 12, 2008 First, you would need full blown VB and not VBA to make an EXE. Most of the code would be identical but the compiler would be different. Quote
ASMI Posted November 12, 2008 Posted November 12, 2008 There is good free program Innosetup to make Setup files http://www.jrsoftware.org/isinfo.php. But you need have many many knowliges to make it perfectly. I have the thick book (about 1168 pages) "CAE system on AutoCAD base - how to make." with common setup creation guide (with Innosetup) for AutoCAD and Autodesk vertical products. But it no English language book, and I seem it has not been published in English. That is book http://oz.by/books/more.phtml?id=1012669&partner=homenet. Try to use Internet search to find AutoCAD installation setup steps or some wizard or guidance. Quote
russell84 Posted November 13, 2008 Author Posted November 13, 2008 Thank you very much guys - i hope i can suceed in doing this. Thanks for the info Cheers. Asmi i've been going over that program - its very helpful thank you Quote
