Greetings!
I'm experiencing problems with slecting objects.
Usually, when I double clicked multi line text, I could edit it, now I get a text: "select an MTEXT object:", which basically means I have to select it again.
Another example of this is quick selection tool. Usually I selected the objects, then went to quick select pop up screen and under "Apply to:" I selected "Current selection". Now, there's only "Entire drawing" option and if i want current selection, I have to re-select it again.
It is very complicated and hard to explain, but I hope someone can figure out what's the problem. This occured recently, but I have no idea why. I checked all the selection options and stuff, but can't seem to figure it out.
I attached some screenshots that may help for better understanding.
Thanks for any help in advance!
You either turned off PICKFIRST and PICKADD variables, or you need to repair reinstall AutoCAD and stop using a Windows Registry Cleaner that was last used.
