I am not able to change the color of a layer in one of my drawing files. When I make a new layer in the drawing file it is the same color as the layer above it (as it should be) but I am unable to change the color in the new layer either.
I can change colors in other drawing files on this computer.
The color of a layer can be changed if I open the drawing file on another computer.
If the drawing is "save as" to a new file name and the new drawing is opened, it still will not change the color of a layer.
If the drawing is "save as" on the computer that will allow the color to be change and opened on this computer it will not allow the color of the layer to be changed.
Have you used Audit on the drawing?
I just ran Audit on the drawing and there were no errors.
Note: I created this file from an existing file using the "save as" command. I do not know of any special setting that may have been made to the orignal drawing.
