Jessica28 Posted January 16, 2013 Posted January 16, 2013 I've asked this question before and have read through posts about Unlocking all layers....ReMark mentioned in one of the posts to create a button for -layer;u;**; which are the steps to unlock all layers...I did this and its great. Thanks. But is there a way to make a keyboard command of it? id much rather hit like "ua" for unlock all and just hit enter....Thanks Quote
ReMark Posted January 16, 2013 Posted January 16, 2013 Possibly edit the shortcut keys in your CUI? Just a guess on my part. Quote
BlackBox Posted January 16, 2013 Posted January 16, 2013 I would define a simple LISP Command instead (being the geek that I am): (defun c:UA () (c:UnlockAll)) (defun c:UnlockAll (/ *error* oldCmdecho) (princ "\rUNLOCKALL ") (defun *error* (msg) (and oldCmdecho (setvar 'cmdecho oldCmdecho)) (cond ((not msg)) ; Normal exit ((member msg '("Function cancelled" "quit / exit abort"))) ; <esc> or (quit) ((princ (strcat "\n** Error: " msg " ** "))) ; Fatal error, display it ) (princ) ) (setq oldCmdecho (getvar 'cmdecho)) (setvar 'cmdecho 0) (command "._-layer" "unlock" "*" "") (*error* nil) ) ... Which can also be mapped to the CUI(x) components; instead of the macro above, simply use something like: ^C^C^PUnlockAll ^P ... Where the LISP above can be loaded via .mnl file. If demand loading is an issue of concern, then simply incorporate an IF Statement in the macro. Quote
BlackBox Posted January 16, 2013 Posted January 16, 2013 Thats great! thanks! ... Happy to help. Quote
