How to create a Read only DWG file or watermark it to prevent theft ?
Hello !
I have an Autocad drawing that I would like to take to a CNC machine to have it physically built out of extruded polystyrene.
I do not want my drawing to be used without my permission or modified.
Is there a way to watermark it or to transform it to a read only file allowing the cnc machine to extract its parameters but not allowing any action upon the file (copy,modify et c.) ?
Thank you !
PS: I have started building my own DIY polystyrene cutting tool out of an old soldering pistol, piano wire,vice, clamps... but it will take some time before I finish building it and there is a chance I might mess up the first few shapes; I need the shapes as soon as possible.
May check if the CNC software is able to process information from DWF files.
is there metadata associated with a DWG file where you can insert the author?
that's it, this is what I would like .
Does it exist?
The man said it was ok; the only problem was that his autocad is an older version (from that I deducted that he can use the autocad file to instruct the CNC machine).
Check the Drawing Properties (DWGPROPS command) under Custom tab.
THANK YOU, MSasu, THANK YOU !
That is lovely !
Can I lock that so it can not be modified by someone else (I mean somebody changing the author)?
yes I can: I made it "read only" by ticking the read only box
Now, I don't know if someone can undo/untick the read only box from the other computer.
Anyone of the mind to "steal" your drawing can either unlock the read only attribute or (even easier) do a "save as" of your drawing under a different name.
Now how secure is your drawing?
There is only one program that I am aware of that can lock an AutoCAD drawing but it costs money.
Up to my knowledge, the DWG password is applied at drawing level and prevents other openning the file; there are no password to be set to protect certain items inside the file as in other formats/applications. So, you are forced to provide the password to the third-part that need to process the file and this enable full access to content.
Can you use a .dwf (not .dwg) file to command a cnc machine ?
probably not, from what I've searched
I will settle for what MSasu wrote: insert author and
the metadata will give me time priority.
Thank you for taking the time and for sharing your knowledge.
