Regardless of the layer I select or the default color of the layer , my lines are all drawing with color 8 , a grey color . This happened after copy & paste of a few blocks from architecturals into my drawing . I can't find any way of making the lines draw to the layer color . . .. . . . HELP ! ! ! !
Thanks Guys in advance for any help you can provide in figuring out what is going on .
Oh thanks you so much my friend , that did it . so many variables . . . so little time . much appreciated !!
Normally you need to change the colour property back to By Layer (when no entities are selected). If it is on colour 8 instead, then all new objects you draw will be colour 8 regardless of the layer they are on.
