Using variables in setting XData DXF Code in AutoLISP
I'm adding XData to user drawn lines utilizing AutoLISP. The following code works fine:
(setq CLoop "CIRC1")
 (if (not (tblsearch "APPID" CLoop))
   (regapp CLoop)
 );end if
(setq xdList '((-3 ("CIRC1" (1000 . "Circuit 1") (1000 . "Reactor Effluent")))))
I'm having trouble substituting variables for "CIRC1", "Circuit 1" and "Reactor Effluent"... I've tried:
(setq LNo "Circuit 1"
       desc "Reactor Effluent"
(setq xdList '((-3 ("CIRC1" (cons 1000 LNo) (cons 1000 desc)))))
I would also like to replace "CIRC1" with a variable as well.
This gives me a bad DXF Group Code error. I've tried various combinations of List and Cons and Quote but can't seem to get it!
Please help - thanks!
Edited by SLW210
add code tags
By usign quote you are preventing the list to be evaluated; please try this instead:
(setq xdList ([color=red]list[/color] ([color=red]list[/color] -3 ([color=red]list[/color] "CIRC1" (cons 1000 LNo) (cons 1000 desc)))))
I was lost in "lists"...
That solved my problem - thank you!
I apologize and will follow the code posting guidelines in the future - thank you.
