DarrenMcT Posted January 19, 2013 Posted January 19, 2013 I am trying to zooom,window in a viewport. When I try to snap to 2 corners of the desired zoom it doesn't allow me to snap. I am using AE11. Any suggestions. Thanks. Quote
Dana W Posted January 19, 2013 Posted January 19, 2013 Nope, windows don't snap. You just have to be Realllllllyyyyyy careful. It is what it is. I try to use the color change of the cross hairs to tell when I have found the corner of something. I do this a couple dozen times a day zoomwindowing on frames around my stuff in modelspace drawn to the viewport scale proportions. I have gotten pretty good at it. When both the horizontal and vertical cross hairs go to inverted color then I know I got the frame corner. Takes practice but it works. Quote
DarrenMcT Posted January 20, 2013 Author Posted January 20, 2013 I have seen it done on previous versions. Thought it would have been some command that needed to be changed. Thanks Dana Quote
SLW210 Posted January 21, 2013 Posted January 21, 2013 I just use Shift+Right-Click and pick a Snap option. Quote
