nkme2007 Posted January 20, 2013 Share Posted January 20, 2013 Sir, I am working on 3D modelling of a building in AutoCAD 2010. The 3D model has 7 elements ie... walls, roof and its constituents and floor and its constituents. I have to mesh the 3D model created so that I can use the meshed model for further analysis. Is there any method for meshing the created 3D model in AutoCAD?Model.dwg Drawing1.dwg Quote Link to comment Share on other sites More sharing options...
Emigrato Posted January 20, 2013 Share Posted January 20, 2013 I guess you are in the wrong place, sir, because here we talk about Civil, not about "normal" Autocad. Anyway, one command to transform a solid into an empty mesh (i.e. a waterproof surface) is _3DSOUT. Then you open a new drawing, and _3DSIN the resulting file. Quote Link to comment Share on other sites More sharing options...
nkme2007 Posted January 20, 2013 Author Share Posted January 20, 2013 Can you elaborate how to use that command, please?? Quote Link to comment Share on other sites More sharing options...
Organic Posted January 20, 2013 Share Posted January 20, 2013 3DSOUT was removed from 2010 onwards. No need to create three separate threads on this issue either. Quote Link to comment Share on other sites More sharing options...
Emigrato Posted January 20, 2013 Share Posted January 20, 2013 You have to manually write _3DSOUT in the command line: if you have no command line, click CTRL-9 to restore it, sir. As already said, this is one of the classic methods to get the goal (I use Map2006) but maybe there are others... Quote Link to comment Share on other sites More sharing options...
nkme2007 Posted January 20, 2013 Author Share Posted January 20, 2013 But, 3DSOUT is removed from AutoCAD 2010 onwards.... Can we do it in any other way, Emigrato? I am sorry Organic, I have post 3 posts in different sub forums that I thought are relevent to my doubt. Quote Link to comment Share on other sites More sharing options...
Emigrato Posted January 20, 2013 Share Posted January 20, 2013 Check if the following tool works on your 2010: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9481286&linkID=9240618 If not, the opensource Blender is able to convert a .DWG in .3DS, sir. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted January 20, 2013 Share Posted January 20, 2013 Welcome to CADTutor. We understand why you posted it in multiple forums, but it is widely frowned upon by forum members and site administrators. I would suggest that you delete your other posts, or we could just leave it for an administrative solution. No doubt it will be moved to the forum deemed most appropriate, and the others removed, if you haven't already done so. It becomes confusing for members who are tracking a thread, if it is shown in multiple forums. Quote Link to comment Share on other sites More sharing options...
nkme2007 Posted January 20, 2013 Author Share Posted January 20, 2013 opensource blender? Quote Link to comment Share on other sites More sharing options...
Emigrato Posted January 20, 2013 Share Posted January 20, 2013 opensource blender? If you don't wanna install a master software like Blender only to convert a file, feel free to _WBLOCK those solids, then attach here the zipped .DWG so I can mesh them for you, sir. Quote Link to comment Share on other sites More sharing options...
nkme2007 Posted January 20, 2013 Author Share Posted January 20, 2013 Thank You sir... I dont mean that I donot want to install the software but I am a beginner in AutoCAD. Attaching the files in next post. Quote Link to comment Share on other sites More sharing options...
nkme2007 Posted January 20, 2013 Author Share Posted January 20, 2013 Sir, please find the model after _WBLOCK.Model Blocked.dwg Quote Link to comment Share on other sites More sharing options...
Emigrato Posted January 20, 2013 Share Posted January 20, 2013 Well, Blender is a non-Autodesk product, so it's independent from Autocad. Check this out, sir. Quote Link to comment Share on other sites More sharing options...
nkme2007 Posted January 20, 2013 Author Share Posted January 20, 2013 Well, Blender is a non-Autodesk product, so it's independent from Autocad. Check this out, sir. Thank you sir... Can I be able to mesh the pipes that are there in the ceiling and the floor also? And, can you help me out about where I can download the software for meshing and how to edit the mesh for further analysis purpose?? Quote Link to comment Share on other sites More sharing options...
nkme2007 Posted January 20, 2013 Author Share Posted January 20, 2013 And sir, can I use the output from blender for CFD analysis?? Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 20, 2013 Share Posted January 20, 2013 Here's your answer. http://www.cadforum.cz/cadforum_en/how-to-convert-a-3dsolid-to-3dmesh-or-3dfaces-tip8318 Who creates a model of a building out of a mesh? What kind of unique building is this? Can you post an image? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted January 20, 2013 Share Posted January 20, 2013 Here's your answer. http://www.cadforum.cz/cadforum_en/how-to-convert-a-3dsolid-to-3dmesh-or-3dfaces-tip8318 Who creates a model of a building out of a mesh? What kind of unique building is this? Can you post an image? Now that's a question that needed to be asked! Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 20, 2013 Share Posted January 20, 2013 I would use a mesh if I were designing a treehouse for Spiderman. But that's just my warped thinking. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted January 20, 2013 Share Posted January 20, 2013 That would be fun to test! Quote Link to comment Share on other sites More sharing options...
