Difficulties with frame generator
Hi guys,
I'm having a problem with the frame generator that I haven't had before. I've drawn the skeleton using some 2d and 3d sketchs. Awhile back i used frame generator to make a partial frame to see how stuff was fitting. Now if I use the skeleton sketch or modify any of the existing tubes (using generator) the tubes will be created not on the sketch lines but will aline yz plane of tube with the yz plane of the assembly.
It previews it like it always does.
Upon creation, this is where it places it. All stacked on top of each other.
Unless I use merge.
Any ideas of what is going on? Did i turn something on or off?
Thank you!
It is also aligning the xy plane of the tubes to the xy plane of the assembly. Its doing this all automatically. So frustrating. Trying to finish frame to send off to get laser cut.
Edited by bearracecars
Ok found the problem. At some point, Flexible had been checked for the frame assembly. No idea why or how.
